Does anyone know a good DVD to PSP converter???
1 replies · 3,478 views · Started 14 June 2008
Hi everyone, I have been using different software for my video conversion needs, but now a little help from you people. I am looking for software that can convert my DVD files to PSP. Please do provide me your feedbacks on the ones that you have used and let me know the results on that.
Thanks in advance!!!
Try Mediacoder.
Its free and ultra configurable. After install choose psp preset. After you can tune as you want. This is the suggested way to use Mediacoder, otherwise it's a bit difficult.
Cheers,
