Bluetooth Audio
11 replies · 2,333 views · Started 06 February 2003
I was having this discussion in the 7650 / P800 pole and thought that I would open it up to others:
Plantronics have a BT headset the M1500 that is available to several markets (sadly no the UK). It is designed to work with any mobile that has a standard headphone jack, all you need to do is order the correct BT adapter for your phone (3 different ones available), pay your money, plug in and away you go.
I was wondering if anyone has purchased / used this, does it work with the 7650 and if so which adapter do you need?
Bob :-?
P.S. I did search the forum first and after going through 200 threads found nothing!!!
Hello all! Im back :angel: ! Why dont you go and trial it in a shop? If the BT hardware is the adapter, which it sounds like it is, then Yes it should work as it doesnt use Phones BT hardware
The problem is that I am in the UK and it is not available here at the moment.
My only option is to buy over the net and then I would have to guess which adapter I need, do you see my dilema (by the way I have emailed Plantronics to get an answer but nothing as yet - if I get a responce from them i'll post it here)?
Bob
:roll:
Here's the link:
http://www.plantronics.com/north_america/en_US/catalog/display_category_type.jhtml?rootId=cat1150057&id=cat1220039&productTypeId=cat1220039
B
Just had a look, its definatly the n1 version you'll need... Keep us updated on the performance etc... Im sure this is going to be a popular product! Well done plantronics!
Yeah, the only times that my phone fell to the floor is because of the earphones, as I forget that the phone is attached to me and then I suddenly move on with the phone on top of the table. Damn.
Please check this link
http://www.crazynokia.co.uk/showthread.php?s=e8aa8d94553b80e9d48d6cdabb6a6d4a&threadid=3962
It claims that you can use the Belkin Bluetooth headset
http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=1&Product_Id=134680
with your Nokia 7650 provided you have firmware 4.39
Anybody have experience with this?
I'd appreciate all info
