Can you save contacts direct to sim card?
0 replies · 15,204 views · Started 17 June 2008
I got my N73 the other week and finally got my number from my old sim on another provider to switch over to the sim that came with the phone.
The contacts didn't come with the switch so I'm putting the numbers back in but they save straight to the phone memory then you have to copy them to the sim. Saving them to the memory will well obviously give the phone less memory and make it slower, I know I could just copy the numbers to the sim then delete of phone memory but then when you search contacts it doesn't show the sim contacts first, just phone memory ones and you have to go to sim contacts through options. Is there a way that when you go into contacts, the home screen shows your sim contacts instead of your phone memory contacts?
