Urgent Problem
9 replies · 2,496 views · Started 06 February 2003
Hello,Can anyone explain me how to upload mid to the 7650? I have PC suite but dont know how to do it...
Thank you
PC Suite does not allow you to transfer midi files.
You can simply send it via bluetooth or infra-red, without using PC Suite. Search the forum for your required method.
That depends on what program you have with your bluetooth device - dependant on which device you have. Do a search on the forum for sending files by bluetooth.
Before anyone else gets in and says it, you could read the manual / use the search function at the top of the screen as other people have asked this type of questio before. 😃
Basically you need to use Bluetooth, IR or download it directly from a WAP / Web site. You can only transfer images with PCSuite not MID files.
I hope this helps
Bob 8)
P.S. Too late Merlin got in before me
I just could not type quickly enough!!!
But that's 8) I don't :evil: you for getting in first, i'll just keep on 😃
You can also attach your mid file to your e-mail and send it your email add of your 7650. Then retrieve your mail, then look for attachments, then play it, then save it. : 😉
Or better yet, use the new app from www.epocware.com 😃
With it you can transfer any file to anyplace on 7650
Of course you need BT or IR for that. 😃
