N78 sound quality
1 replies · 7,244 views · Started 21 June 2008
i just got my N78 and overall i'm really content with it.
The only problem i have is about the sound quality of the player. It seems that my old K750i still reaches better results than this much newer device. That is a real issue for me as I use my cellphones as my mp3-player mostly.
It's mostly about the bass booster functon which sounds just great and impressive on the 750i and really terrible on the N78 with a lot of noise.
My question is now if theres any possibility to fix this problem maybe by using a software upgrade or if this is a hardware related issue :S
Another question would be if anyone can compare the sound quality of the N78 and the N95, so that the N95 might be an appropriate replacement if it provides better quality.
Thank you for any answers 😊
It's possible that nokia could fix this with a firmware update in the future but for now, there's not much you can except try different things in the EQ. I got a custom one that sounds not too bad.
