Hi rdcinhou,
>Thanks for the feedback--I was beginning to wonder if maybe this forum for the 9300 was dead.
There seems to be very little happening on any of the S80 forums now. Perhaps Nokia et al need to take note of what Asus have done with the eee PC and reduced prices significantly.
>I use Macro Express (similar product to your AutoHotKey) on my PC, but was not really looking the the RapidReader PC-based product, but instead the version for the Communicator series 9300/9500.
I realize that you were seeking feedback on Rapid REader on the 9300, but I was only suggesting a trial of Speed Reader as a concept. After I had tried Speed Reader I decided not to purchase Rapid Reader.
There was also a very early beta version of a freeware reader called Serial Reader or SReader v0.01 by Lance Wicks. I have the OPL code on my 9300, but I cannot remember which of the various forums I obtained it. As it was a very early version, it was not able to read text files and only used data lines in the program to demonstrate the concept. I had intended to have a go developing it a bit further, but when Speed Reader on my PC proved to be disappointment, I did not spend any further time on Serial Reader. Perhaps it might be a project for you?
>Whenever someone with a new-fangled iPhone, Tilt or other comes by and tries to show off the features of their new toy--I whip out my 2+ year old 9300 and start showing them spreadsheets, databases, PDF's, e-books, wide-screen videos at high bitrate (SmartMovie), Symbian Basic, OPL programming language, JI Prolog and more.
>While those persons usually aren't interested in the getting-work-done aspect, they normally concede that my "video looks better then that on my iPhone/iPod/etc.".
There seems to be less interest in amateur programming these days and more of just playing with the gadgets!
>Since discovering the Gutenberg Project I have started reading a lot of free e-book (mainly classics) and other web-based material that I can compose into my own e-book with MobiPocket Creator (free).
I too use MobiReader quite a lot on my 9300 and build my own ebooks from material on my PC (job corrospondence, refererence material, web material etc) by using TreePad on my PC to export to html files and then import these into MobiReader 5.2 on my PC which I then transfer to my 9300. Some of these prc files can be up to 5mb and seem to run happily on my 9300.
You might like to try the EasyReader macro on the FileNote website to further enhance the MobiReader experience.
>I am reconsidering getting RapidReader for the 9300 as I could increase my throughput and have yet-another-program that has no equal in the iPhone world!
Since starting to write this reply, I have discovered that you can download a demo version of Rapid Reader. Go to the RR Windows page, find the download trial link and select the Symbian version. Unfortunately, I have been unable to get it to run. The first time it is run, I get a message that it needs to import a TimesRoman font and it will need to re-start the device. The next time it crashes with the error message Reason code: kern-exec, Reason number: 3
I have also tried installing on my old 9500 and it falls over during the install with the message: "Unable to find specified object"
Perhaps you may have more luck.
Regards,
Martin O'Neill
