New to 6120Classic
3 replies · 4,021 views · Started 22 June 2008
Been using the 6233 for over year and got used to the functions.The 6120c seems to lack many of the 6233 functionalies.
1. I use the reminder function alot. This function is no longer there. Can I download and install it?
2. If I use the 'to-do' function. What is the fastest way to copy the same 'to-do' task to another time or day. In the 6233, I can just copy to differenet time, day, days of week, etc.
3. On the 6233, I can program short-cuts the up, down, left and right Navi keys but 6120c. Any way to program the 6120c Navi keys to do short-cut to message or calandar?
4. If the the 6120c does not these functions, which current Nokia models offers these functions. The N95 also does not have remimders.
Hope someone can help me with these question?
Thank you in advance.
Different things here... 6233 it�s an S40 phone without an open OS.
6120, it�s an S60v3 phone, with an OS personalized.
After that:
1. I don�t know the modern S40 phones, so I don�t know exactly what�s that "Reminder", but it�s possible to put a lot of things on S60 phones. Just take a look at software section of this site.
2. Just use the * key, and make a copy / past content.
3. Turn - off the active screen, and you can assign to the navi key the function you want.
4. Exactly what you talk, should be on S40 phones, like 6267, 6500, 5610, 3120 or the new 6600, all S40 phones.
Thank you for your reply.
Solved the Navi keys issue.
Will have to look at the 6600 to see if the feature set is similar to the 6233.
I have another question. This time regarding contact list. If I key in say 'l', it show names with 'l' in it rather than listing it alphabetically.
Any way to change this?
Thank you
