Cannot install Handy Blacklist after firmware update?
3 replies · 3,592 views · Started 23 June 2008
I'm having problems installing Handy Blacklist on my N95 after updating the firmware to V13.0.003.
Prior to this update everything seemed to install fine, now when PC Suite asks me to continue the installation on the phone, the "install" part only stays on the screen for a short period of time before disappearing.
If I press it in time it seems to start then disappear also, if I bring up the task manager it says the installation is still active but I cannot bring it back to the front and I eventually get the message "installation cancelled".
Has anyone else had any issues like this after an update? Or does anyone have any suggestions of what may be causing the issue?
Could be a certificate problem. Change the phone date to a previous date, like all year before the upgrade date. See if it works!
J2theIZZO wrote:Hi,
Assume you did NOT restore a backup after the Firmware upgrade?
If you did, format the phone memory and try the app install again.
No I did no restore of anything, was a complete fresh install - and there is no SD card present.
May try re-flashing the phone again and see if that makes any difference.
