How does n82 compare to my sluggish n73?
4 replies · 6,217 views · Started 23 June 2008
Hi all,
I love everything my N73 can do, but its so unresponsive it drives me to distraction.... If I want to write a text it can take 7-8secs for the text app to load in before I can even choose recipient.... Camera is a similar delay. I've tried sw upgrades and this is my 4th handset.
As a result I want to change the phone - am changing due to the speed not to add features, though any new featured will be welcome!
can someone tell me how the N82 is to use? - after a period of time, with applications loaded on and plenty of contacts, changing camera from stills to video mode, speed of camera startup etc etc....
Cheers in advance
Sean
N82 is a great phone... improves all about n73. All works well, quickly and make only time to time on or another reboot. The only draw against N73 is the "dust"... N82 have a bad construction, and with 2 weeks of use, already have dust inside, on screen and frontal camera.
seanski44 wrote:Hi all,
The N82 (and N95-8Gb) have much higher RAM (88Kb free after bootup) which makes everything more responsive in the menus.
The N82 also has the best camera of any N-Series handset (5MP Carl Zeiss and a REAL flash).
I totally recommend the N82 - in fact I am not even sure if an N96 is 'better' in any way
It all depends on what exact feature you are looking for... To me
Nokia N95/Nokia N86 are solid phones .... Upgradation worth from Nokia N73 to these phones...
Also if you want to look for other phones, Nokia N79/N85 are also there :icon14:
But Nokia N95 and Nokia N86 are better 😉
