n78 product codes?
16 replies · 15,994 views · Started 23 June 2008
Hi
I am form Serbia, and my n78 has no fm transmiter!
Does anyone knows product code for software update, so I could use this featre?
My current product code is 0564477
It would be nice if anyone who has this phone with fm transmiter working write here their product code.
Pogledaj ovo:
-http://thesymbianblog.com/2008/06/11/all-regional-variants-of-n78-will-not-have-an-fm-transmitter/
Za product code nisam na�ao ni�ta osim da po�alje� IMEI i plati� neku lovu pa ti po�alju SMS-om....
cagi wrote:osim da po�alje� IMEI i plati� neku lovu pa ti po�alju SMS-om....
Na koji broj da osaljem imei pa da dpbojim valjan product code?
Where did you find product code, on that link I send you, or?
Does FM transmitter works now?
cagi wrote:Where did you find product code, on that link I send you, or?
posto vidim da znas srpski, sto da se smaramo s engleskim.
product code sam nasao preko zvanicnog zastupnika za srbiju, zaboravih naziv firme, ali ga imam u garanciji.
najvaznije mi je da garancija i dalje traje ( godinu dana) a fm transmiter radi.
pozdrav
Mislio sam da si na�a neku stranicu s product code-ovima pa sam zato pitao!
Taj tvoj product code je 'Balkan'?
Drago mi je da ti sad sve radi, inače mob mi je odličan (izgledom) i namjeravam ga nabaviti!
Ali sad sam tek dobio T-Mobile MDA Compact III Navi pa ću vjerojatno pričekati neko vrijeme...
Pozdrav
I changed product code on my hong-kong n78 to try to get french predictive text input. But I can't get the firmware updated either by NSU or over the air. How can I trick the phone into making it re-update its firmware?
It will update if there is newer firmware available, so your phone is probably already up to date. When a new release comes out, the firmware update will then work
Im not aware of a way of forcing it to upgrade unfortunately
Does the product code will make different language characters to show, like Traditional Chinese and Japanese?
zna li neko neki link sa detaljnim uputstvom kako se menja product code???
znaci ubih se trazeci i nikako da nadjem nesto konkretno....
thanks for the codes, my sister needed one..but i told her the same thing i'm tellin you guys. it's just much easier to buy your phones already unlocked if you have at&t and t-mobile. i've been getting mine from gsmallover.com and i'm going to keep getting them from them until i find another website with better prices and service..but i haven't seen one yet!
