SecureDrive is a unique program that allows you to keep your data in secure form without you having to think about it. All these actions are performed "on the fly" and are transparent to you. Program adds new disks visible as regular disks and you can work with them as with regular ones - store your files there, install applications onto these disks, run them, etc. But you can be sure that your data is confidential.[read more]
[new] SecureDrive from Symbianware
wow...A big step further from Idisk Pro
Congrats...
