I have Problems with the sync with Outlook.
I have succeded syncing with it, but now I no longer can do it. All since the start I havbe had various problems, and I'm getting this error message everytim I start Outlook (for those opf you understanding swedish).
[code:1]Ett nyligen installerat program kan orsaka att Microsoft Office och andra program med e-postfunktioner inte fungerar som de ska. Outlook kan l�sa denna konflikt utan att p�verka programmet som orsakar problemet. Vill du att Outlook ska l�sa problemet?[/code:1]
The sync problem is that it starts syncng, but then never finish it... it just stalls...
I have tried reinstalling both Outlook and the SE software...
Anyone having had this problem?
