Portable printing
5 replies · 6,620 views · Started 25 June 2008
It is possible to print via IR, Bluetooth and WiFi, so you'll need a printer (or print server) which is compatible. I print to an HP5550 connected to an Apple Airport Express via WiFi, and it works a treat....
I think there's some sort of HP driver built in, but unfortunately I can't check it for you at the moment, as my E90 is currently drying out after a water-bottle "incident"....
There is another way to print from E90
you can use ContentBeamer program and send your document you need to print as a FAX to your fax machine
- Just to make it complete:
You can print to any bluetooth or wifi or pictbridge compatible printer. Obviusly for picbridge you need the usb cable. You do not need any driver to print. And content beamer prints to fax, but it's not free.
I suggest HP if you are planning to buy one. Actually thease printers are more expensive than the regular ones. HP got one model with rechargeable battery. You can find very small printers as well if you google "small bluetooth printer" or something like that.
Cheers,
