Aktive desk
4 replies · 2,187 views · Started 14 March 2002
I installed the last version off Aktive desk.
It displays the possibility (in the sub menu "CTRL S"😉 to show the clock (just in full screen mode), but i can't activate it, and yes i am running it in full screen mode!
However i didn't register yet.
Is it possible that this is only to be aktivated in a registrated version?
Regards;
Ren�
If you don't have the option in the View menu (Shift + Ctrl + T), then maybe you're using an old version?
When the new version was first released, the ActiveDesk web site had a little bother with the link in that the link for the new version pointed to the old. This was a while ago and has since been fixed, but if you downloaded it a while ago, maybe that's the issue.
Thanks for your reply!
I downloaded this programm yesterday!
Version v1.55(c)
Vieuwing full screen mode is no problem, this works well.
But when I am in full screen mode and then press CTRL S, then take the secend tab (view), there is an option to activate "vieuw clock, (only in full screen mode)".
However, this is displayed in grey, so it is not available..........
I looked in the helpfile but there is nothing that described this function.
Ren�
I think you need to have it registerd to see the time!
Since the time will be displayed where the "Not registerd" text is on the unreg version.
