Manufacturer's Bluetooth kits
1 replies · 1,695 views · Started 25 June 2008
I'm looking in to getting a new car and was thinking about getting a factory fitted bluetooth upgrade while I'm at it.
Just wanted some advice on what manufacturers car kits work well. Unfortunately I'll be looking at non premium makes. can't afford the likes of BMW and Jag 😞
Thanks in advance
8Ball
8Ball wrote:Hi,
Thanks in advance
8Ball
Now I've seen it all...😎
You'll choose a new car depending on the built in bluetooth kit???😊
