Hi.
I have two n73's(black) the product key is 0554501. When I open nokia software updater and run it, it tells me that I currently have the latest firmware installed. V4.0738.3.1.1 RM-132 18-09-2007. When I change my product code with nemesis(multiple times) and then run the software updater, I get an error message saying that there are no updates available at this time. Has anyone else had this problem? Thanks in advance
Ok. So when I go to the nokia update checker http://europe.nokia.com/A4577224 And put my product code in, this is what it shows.
Latest available software for Nokia N73, product code 0554501
Version: 4.0738.3.1.1
But if I put a euro code in, it show this instead.
Latest available software for Nokia N73, product code 0529602
Version: 4.0812.4.0.1
But if I change my product code to the euro code with nemesis, then run nsu.
It will tell me that theres no update available.. If I change it back to my original product key, it will tell me that I have the latest firmware and I can reinstall it if I want. With the euro code, it wont even ask me if I want to reinstall. So im guessing, has nokia updated the way their nsu checks the phone model? Im using the latest nsu.
Is it because I have rm-132? Does anyone know where I can get rm-133 firmware and use phoenix to flash it?
Disregard. I just followed this guide. Worked like a charm. I now have rm-133!
http://www.allaboutsymbian.com/forum//forum/thread/72134/
