Hi.
I have an e51 which is having problems getting ip address from dhcp server.The network where i having this problem uses a dhcp relay to communicate with the dhcp server.
Different tests on other (simpler) network configurations , the cell phones works with no problem at all.
There is one post i found in here where someone seems to have the same problem (getting an ip address through a dhcp relay) but apart from manually assigned ip address there is no resolution to this.
any help?
thanks
