I can save sent or received SMS messages in maps I've created. Is this also possible for mails, using the native mail porgram (POP3 Account)?
Thanks,
Ljad.
Saving Mails on Nokia E90
How do you save messages in maps? I'm not sure what you mean? The GPS possition when you send the message or what? How do you save your SMSs?
My question is: I create a folder (or map) called "Mails". How can I save incoming mails into that folder ?
This is oneof those stupid things that i think has happened since s60 v3, you can save sms's but not emails, i have absolutely no idea why this has been overlooked on later devices, it was possible before. My previous N95 was the same, most annoying. One solution is to use profimail, much better than the built in client imo.
Thanks, we will have to live with this! But I 've just installed Nokia's new "Nokia E-Mail" program (Beta release). This works quiet fine, and you can store mails in folders and even install push mail. Good ! I Will use this in the future.
Ljad
