w960i problems
4 replies · 7,514 views · Started 28 June 2008
Hi
How do you transfer music to the phone if you are running a pirated copy of windows xp and thus cannot use errikson suite?
cheers
just a question, why are you unable to run the PC suite? even though you have a pirated XP copy?
Doesn't matter what O/S you're running, or how legal it is...
...You have several ways of connecting to the PC. Bluetooth, USB, or Infra-red. Most common (and easiest to set up) is to connect via USB.
In actual fact, you shouldn't even need Sony Ericsson PC suite if you connect via USB. Chances are that the moment you connect in 'Fast File Transfer' mode, your PC will recognise the 8gig memory in the phone as removeable memory (just like an SD card).
Then just transfer your music in the normal way. No hassle, no Sony Ericsson media manager (which is a temperamental and clumsy piece of software), and no configurations. - The most you may need is the Sony Ericsson device drivers, and you might not even need them either!
xtacy wrote:just a question, why are you unable to run the PC suite? even though you have a pirated XP copy?
I cant update from sevice pack 1 with this pirate copy and the media manager dont seem to like SP1
trelloskilos wrote:Doesn't matter what O/S you're running, or how legal it is...
cheers for the info, Ive sorted it now.
