All I Want Is Sat Nav!? Help!
5 replies · 2,171 views · Started 29 June 2008
Hello, sorry if this is a repeative ask but I'm slightly behind the times and have just recieved the 'plum' N95
what i want is a sat nav that works,
i've heard tom tom 6 is good. where can i get or download a copy of this for free or at least at a reasonable price........... and where do i go from there?
sorry, not hugely inteligent when it comes to phones- but willing to try!
thanks in advance for your help!
Mark
Do not ask for it for free - this isnt the place to ask for cracked software.
Your right in saying this has been asked before, theres hundreds of threads about this.
Do a search, but whichever one you decide to go for, its going to cost you, the cheap ones are just not as good.
garmin is the best n95 GPS solution, because tomtom doesnt work with internal GPS. and honestly i like garmin's slick UI look anyway...i also use nokia maps, but garmin is way better looking and functions better. nokia maps has a better search though with 2.0 because it goes online. however i just upgraded my garmin maps to 2009 version, and holy crap the maps are much more updated now. its perfect.
Hey Roger, could you explain how you did it and the upgrade process? I have been meaning to look into this, as Im not yet sure how to upgrade the maps on the Garmin mobile XT version.
