I can't make Zip files of videos
1 replies · 1,785 views · Started 30 June 2008
I am unable to make the zip files of my videos. It seems larger sized files are not supported by the zip application of Nokia N95. I tried to make the zip file of video with size 80MB or more, and it always displays an error as disk drive is full.
Can anybody suggest how to make zip files of larger video files using N95 zip applivation.
why do you want to anyway? video files are already in a compressed format and zipping won't achieve any meaningful compression rate; you'll probably only get about 1% reduction in size at best.
