Symbian won't boot (hangs on the white screen after the nokia logo)
0 replies · 11,869 views · Started 30 June 2008
Hey guys,
I was cleaning my 6120c from unused applications, so I went through all of them and uninstalled the ones I don't use.
I can't remember the application I was uninstalling, but the un-installation process hung for a while and the phone didn't respond. I had to remove the battery.
That was the last time I was able to start up my phone. Each time I pressed the pencil key to start it, it displayed the Nokia blue logo image and then a white screen. That's all. And again, without removing the battery there seems to be no way to turn it off.
Also, when connecting it to a computer (usb cable) 6120c won't even show signs of life. Windows recognizes it as something like "Nokia Rom" instead of opening it, like before this happened.
Please, I need help! I don't have another phone to use atm! 😃
Thank you all.
