I've had so many programs on and off of my N95, that it's about time i had a complete fresh install.
Is there anything to beware of...I have my contacts and diary backed up.
So i hope thats it
So i hope thats it
just make sure everything you need is backed up
i only back up contacts really and bookmarks then i reformat and install the apps i want manaully mate 😊 i find thats the best way as restoring settings etc can just lead to problems
hope that helps
The hard reset does not wipe the 8GB memory? How can this be possible?:con?
VJ_UK wrote:The hard reset does not wipe the 8GB memory? How can this be possible?:con?
Hard Reset on all Nokia smartphones only formats the "Internal" phone memory.
MicroSD cards on the N95-1 and "mass storage" on the N95-8Gb is excluded from the auto-formatting process.
It's always been this way.
Thanks for the info Dez_Borders.:icon14:
How can the mass storage be formatted:con?
VJ_UK wrote:Thanks for the info Dez_Borders.:icon14:
I don't have an N95-8Gb, but I guess it's a similar process to ther N95-1 & N82
Menu->Tools->Memory->Options->Format Memory Card/Mass Storage
