Podcast App
7 replies · 3,567 views · Started 01 July 2008
the podcast app on the phone is ok. I currently add new podcast via this app.
But am restricted by the availability.
is there another app or another way to add feeds of other podcasts that are not listed on the Phones app?
regards
you could use the web browser and wifi to visit your normal podcast websites 😊
thats what i do mate and as your using wifi it will still be free
hope that helps
buxz777 wrote:you could use the web browser and wifi to visit your normal podcast websites 😊
hope that helps
yeah i could, but was hoping i could add a feed to the existing software of the phone! if that's possible ?
winnie wrote:yeah i could, but was hoping i could add a feed to the existing software of the phone! if that's possible ?
Are you talking about the Nokia Podcasting app? You need to go into "Podcasts" then "Options", then "New podcast", then type in the URL of the podcast.
You can paste the url into notes using pc suite on pc. Then highlight and copy to the app with the pen key.
Take a look at mobilecast.
Create an account and download the application,
then you can manage your podcasts online.
If you have a data plan it's even better, as you can "stream" the podcast instead of downloading it
Been using it forever and think it's great.
Sorry i spelt it wrong
MOBILCAST
http://mobilcast.com/
at the bottom of the front page on the right is the link to the mobile phone app
remember once it's installed follow the "link to web" instruction, and all your podcasts selected via pc will be there on the phone to either stream or download.
My only critisism is the website is rather slow
