I had to have my E61 repaired and am now trying in install several of my programs and several of them are saying they won't install because the Certificate expired. It has said that on most of my programs. When I had my device repaired of everything was taken off including my settings. It seems to me that we had to make a special entry somewhere so that it would accept the certificates. Some of my software installed fine.
surely if you don't use a program that you uninstalled and try to reinstall it the Certificate runs out???? That happened to for example Jukebox, Smartmovie, Profimail etc.
Any advice please???
Thanks,
Bobby
Back to using my E61
By the way before anyone says anything about back up I did back it up but I reset some stuff on my PC, remember if it works don't mess with it, and lost my backup.
Thanks,
Bob
Set the date on the phone back a year or so and install your programs. Should work.
Thanks I will give it a go.
Thanks,
Bob
Yes it worked thank you very much. Actually I had to do two things one was as you said reset the clock and also do the Certificate Error change to all on my device. Then I had to on some of the program leave it set back a big and then for some had to move it to the correct date. But it worked great so thanks.
Thanks,
Bob
