pls can som1 hlp me out.
my 3250 kips on tellin me to insert sim when i try to change
a profile.
tnx!😎
insert sim
pls hlp me out
Try a different SIM card. If that works, replace your SIM card. If it doesn't, you can try seeing if a firmware update helps ( http://www.nokia.com/softwareupdate ). If that doesn't help, either, then take the phone to your nearest Nokia repair center ( http://www.nokia.com/repair ).
