Track my route and compare?
4 replies · 3,155 views · Started 04 July 2008
Is there anything about that can log my journey using the GPS and then compare it later (either on the phone or on a computer).
What I really want to do is try out some routes to and from work and see which is quickest. Obviously I could use google maps but some routes involve a lot of traffic that it doesn't take into account.
Sports tracker, I do that very thing lots of times.
I dont know about compare, but by simply looking at the KML file information (time, distance travelled etc) you could get a pretty good idea.
I agree, sports tracker. You can compare on your phone, upload to the sports tracker website to view on a satellite overlay there (which can then be shared, if you want), export to a KML file to copy across to the computer and import manually, etc.
But if you want to know what's quickest, can't you just time it?
Of course, never though of that. I think my mind was going down the sat nav route (no pun intended).
I use sports tracker and the online service for running already so that makes sense.
sports tracker is what i use too. you can then upload the sports tracker file to google maps, and it overlays the route onto a map with info showing your speed, time, etc.
