jus bought a NAM N95...have some questions
18 replies · 5,403 views · Started 04 July 2008
hello, after a year of using my crappy Motorola Z6 i decided to buy a NAM N95...but i did have some questions...does the NAM version get frequent F/W updates like the European version??...i have heard the NAM is more buggy/slower than the European..is it true??...any other differences between the NAM and Euro model???...please help...thanks:con?
There has been one firmware update released for the N95-3 NAM. It was released in late May or June. I have not updated my phone to it so I cannot comment on it.
The earlier European version had more updates because it had more issues to resolve, in my opinion.
Is that the update that makes the phone slower???...i heard that some place that if you update to the latest one for 8gb NAM the phone gets "slower".....and do the NAM N95 8GB's have the "loose slider" like the classic N95's?
No the nam is not slower. The -3 finally got the good firmware update. And the -4 has the latest firmware too. My -4 had a loose slider but i fixed it in 5 minutes and its been rock solid ever since. All n95s are the same now.
RogerPodacter wrote:No the nam is not slower. The -3 finally got the good firmware update. And the -4 has the latest firmware too. My -4 had a loose slider but i fixed it in 5 minutes and its been rock solid ever since. All n95s are the same now.
"fixed it"....how???....is it easy to fix?
I was lookin on you tube at the the cool accelerometer appl;ications...but it says i need "python"...WHAT IS PYTHON lolzzzz:con?:con?:con?...help please
python is a software that many writers are developing apps for. it allows them to code very easily and quickly. python is the latest thing i've gotten into on my 8GB cause there's so much cool stuff coming out from the python app writers lately. made me totally into my phone again. its free just search and install the python app and script shell or whatever its called. so 2 things you need to install. i find all that stuff and the python installers over at symbian-freak.com in the forums. TONS of stuff over there, go check it out. i also use howardforums.com in the s60 forum for all the n95 info and help you could ever want. of course allaboutsymbian is my top reading too!!
but the majority of the n95 apps are just regular apps out there, not related to python.
for the slider fix, i used the video on youtube to guide me on taking apart the phone. but instead of using the tape trick like the video shows, i bent the metal tabs on the end of each metal rail, and the slider was so tight i couldnt even open it at first! a slight adjustment, and perfecto😊 so you can make that thing solid as you wish.
for simplicity, just use the tape at first if that makes it easier for you. either way, the entire fix is super easy unless you really are not mechanically inclined. oh and the full tutorial is at www.n95users.com.
OOOOOOOOoookk hank you thats about all i needed to know.....im phone will be here tommorow so i cant wait!!!!!!!!!!!!😎
One thing about latest firmware for the N95-3 NAM version-No ASR (Screen auto Rotation) some genius decided North American users did not need this enhancement. I tried installing Rotate Me app from Samir but cannot due to a issue I can't seem to figure out. I installed this fine on two other N95-2 and N95-4. This is a cool app.😊
i have FW v 1.2.011
28-01-08
nokia N95 (a6.01)......................is this the latest FW??....should i update....and forsome reason i thing the phone i recieved is not NAM...it's just a regular 8gb....how can i tell????:con?
that is the n95-4 with the original firmware. there is an update to v20 something, but it doesnt add anything new so i didnt even update my phone. i would just stick with your current firmware unless you want to have the latest and you didnt customize your phone yet, so you wont lose much doing the update now. i was too lazy to update mine at the time...
i updated it to V20.2.005......i dont see many diffrences.....Oh and is this the latest??....and i cant get rock and scroll to work i signed it using symbiansigned...and it even installed correctly...but whwn i go to open the app it just flasses and goes away.....whats the problem??
yes its the latest. and that's why i didnt even bother doing the update, cause nothing new comes with it. i dont know about that app so i cant help....
im having a problem when i reocrd video on my camera the cam all of a sudden auses then recordas again...it keeps doing it....any one know about this?
armada741 wrote:im having a problem when i reocrd video on my camera the cam all of a sudden auses then recordas again...it keeps doing it....any one know about this?
does the video stutter a lot when recording? yes this is a known problem. for some strange reason that nobody can figure out, some n95 8gb phones have this problem and others dont. to fix this you have to format your mass memory 8GB. so make sure you copy any important files, songs and pics to a computer or something. then format that sucker. now your video will record nice and smooth.
this happens even on some brand new phones. i didnt have this problem though...
hmm...yea my hone is les than 3 days old and it's pausing and stuff..i will format it and see it it works...
