hey guys i'm not able to find any Wlan network when i do the scan in my E90
although i can find it through a laptop or another phone
how i can solve this ?
thanks
thanks
anyone ??
since you haven't stated any of your settings maybe start with the basics and go from there:
If you go to TOOLS - Settings- connection-wireless LAN, is the option to "show WLAN availability" set to YES?
HLing wrote:since you haven't stated any of your settings maybe start with the basics and go from there:
yes this option is set to yes
and when i turn the WLAN scanning it cant find anything
had you ever been able to scan and see a list of available networks? Or is this condition the way it has always been since you got the e90?
The reason i ask is that my e90 sometimes will scan and show ALL of the networks available except for the one network i have wep key for, because it had been in the list of defined "access point" (tools-settings-connection-access points). What i had to dco was to delete that network from the access point list. Then somehow it will show up wqhen you scan. Just make sure you have thed key handy because e90 will ask for it.
hi all,
I was having same problem in e90.... no WLAN network found.
Few days back my router was not working properly and I changed it to Gegaset. and that time my network in e90 was working perfect. when I set WLAN secure password in Gegaset, in e90 no WLAN network found.
cancel secure WLAN password or reset your router setting, I hope it will be ok.
Enjoy.
hi all,
cancel secure WLAN password or reset your router setting or tick Enable SSID Broadband, I hope it will be ok.
Enjoy.
