Hi everyone, I have got the N95 8gb Nokia phone which hasn't got Turkish Language on it, if I update my phone to new firmware Version: 20.0.016
will I have Turkish Language if not, how can I add Turkish Language?:con?:con?
Living in UK and my Phone version: 11.0.026
thank you in advance and regards...
Gen...:
first that you don't already have turkce available .. through the personal language option described below.
If not then you need to change your devices product code to 0534845 - Turkey .. check the sticky note on how to do this at the top of the Thread List.
Once you have changed you may alter the language through menu / tools / settings / general / personalisation / language (you may have to scroll down) / phone language .. writing language etc ..
Good Luck!😊
seki wrote:first that you don't already have turkce available .. through the personal language option described below.If not then you need to change your devices product code to 0534845 - Turkey .. check the sticky note on how to do this at the top of the Thread List.
Good Luck!😊
No I am afraid there isn't Turkish Language on it at all, that means I have to change my phone code to 0534845??? are you sure is this the right code for the N95 8GB???
I don't want to do mistake, and also do have to back up my phone before and once I change the code will I be able to put everything back on as it was before???
Thanks again..
regards...
Gen...
gentlemen wrote:No I am afraid there isn't Turkish Language on it at all, that means I have to change my phone code to 0534845??? are you sure is this the right code for the N95 8GB???I don't want to do mistake, and also do have to back up my phone before and once I change the code will I be able to put everything back on as it was before???
Thanks again..
regards...
Gen...
Check it .. if you like I think I copied and pasted it correctly :P
So yes .. you will have to change product code .. as described in the sticky. Good luck!
seki wrote:Check it .. if you like I think I copied and pasted it correctly :PSo yes .. you will have to change product code .. as described in the sticky. Good luck!
Thanks for advice Seki, here is what I found on the sticky...
N95 8GB product codes
0550370 - TURKEY
N95 product codes
0534845 - Turkey
I believe the first one will do my Nokia yes?? and also do have to back up my phone before and once I change the code will I be able to put everything back on as it was before???
SW version:
V 11.0.026
01-11-07
RM-320
N95(c)NMP
Gen...
you are right! .. OF course back up all your stuff to a PC before doing anything like changing the firmware - IT WILL wipe everything on your system drive on the Phone.
The sticky on debranding is pretty comprehensive .. you could always take a peek at my old Youtube clip on how to do it .. http://www.youtube.com/watch?v=uN9eRlddfH0
Good luck!😊
Hi Could anyone help me to change menu on my N82 to Turkish Language?
it is bought in UK.
