Restore Factory Settings
4 replies · 3,402 views · Started 07 February 2003
I am a new 7650 user, recently i encounter a problem; i wanted to delete a saved game created by the default game "Mix Pix",but the phone options don't allow me to do it. so I was wondering whether by restoring the phone to factory setting can help to erase it. Or is there any other way to delete it away from the phone itself. Please off your wonderful help.
u can use seleq or e file manager to delete them. guess u can do that reseting ur phone as well the code is *#7370#
you dont need to reset or use seleq
I think there must be delete option
it is the 5th one in the options menu
you must be highlited the game you created. and you know the rest.
Well yes there is this option, but when execute it, will it delete the entire "Mix Pix" game from the phone or just the saved game created?
