i have Nokia 9300 with product code 0518937. Applications like MobilReader, Bounce, .. which i get with the phone is working fine. But, every third party application which i'm installing is not working. When i open the application, i get the message: "System: Unable to find the specified object". I was tried to reset ini files but after, situation is the same.
Please, can anyone knows what is going on?
Thanks.:con?
"Unable to find the specified object" on all third party apps
Searching the Nokia developer's forum, this is a common error message from Java applications when the software you are running is not compatible with the platform (i.e. is it not for the 9300).
Best bet...uninstall the application and then search carefully for a version that is intended for your version of Communicator.
What applications were you trying to run?
