N95 Data Usage
3 replies · 3,605 views · Started 11 July 2008
A colleague has a N95 on Vodafone, checking through the usage history on the phone it appears the device has received nearly 1gb of data in the last 30 days.
Checking the "Call Log" shows no connections (inbound or outbound) via Vodafone or any Wi-Fi activity.
Looking at the online data stats provided by Vodafone as part of the itemised billing the phone is connecting at 2-3am every morning and pulling down between 2 and 3mb's of data.
Is there a utility I can use to trace whats pulling the data at this time in the morning or work out whats happening?
Cheers,
Gavin
gavinlew wrote:Hi,
Cheers,
Gavin
FORMAT both the internal and MicroSD memory and the problem should stop.
Alternatively, switch off the handset when he/she goes to bed as the transfer always seems to be 2am.
Hi Dez,
Yeah we've done that - Vodafone have disabled Internet access (GSM) as well.
Would of been nice to see what application was performing the data transfer at that time of day.
gavinlew wrote:Hi Dez,
If you have formatted both internal and memory card, there should be no apps installed to send or receive data... ??? Did you restore a backup after formatting?
