Hi;
My N95 Fell into water for seconds I took it out then I left it off couple of days. When it dry I turn it on I found out that every things work fine except the SD memory I tryid another new memory but the same problem the phone can't sense it !
When I insert or remove the memory no messages or error appear, it look like nothing in the SD port!
What Can I do ?
Please help
It might not hurt to pull the memory chip out, using a q-tip and alcohol to clean the gold contacts, and then it might help.😊
There might not be much to worry about. My girlfriend (at the time) soaked my 9110i communicater in vodka and red bull a few years back and the same thing happened... wouldn't detect any MMS cards put into it.
Then a couple of months later it just started working again.
If you're patient, I'd suggest this course of action. If not, try countrybumpkin's.
