I would like to avoid loading Windows with the SE Suite for smartphones. Is there any way to extract from the CD (or to download from somewhere) just a) the IrDA drivers and, may be, b) the m-router module? Do you see any drawback in such an approach?
IrDA drivers/ m-router module
Just to share my finding:
- drivers (USB, Irda and BT) can be found here: http://ma3-origin.extranet.sonyericsson.com/drivers/open.html
I also believe that you can find something in the SE CD under the path \Drivers\USB Cable\ AND \Modem scripts\ although I haven't done a detailed analysis
- m-router can be found here http://www.4shared.com/file/4746412/e2552a21/mrouter3installer_v31042. html and I believe it's a more recent version than what comes with the SE PC Suite (3.1.0.42 vs 3.1.0.28).
Still unkown if everything (connection with handset) works without the SE PC Suite
