Apologies if this has been covered before...
I am currently using Mail for Exchange to connect to my Exchange server and sync my mailbox on my N95.
It works fine, however what I can't do is sync any of the public folders on the Exchange server with my N95. Is there an application (preferably free) that someone could recommend that has this functionality?
Note that I want to be able to sync over the air when out and about....not connect to a client PC and sync.
No MFE has no multiple folder support.
Unplugged wrote:No MFE has no multiple folder support.
I understand that Nokia MFE doesn't support multiple folders. I was looking for a solution that did.
The only way that I can think of getting the contents of an Exchange public folder to sync over the air is to do a one way sync, public folder to personal folder, on the client (Outlook).
It would work but its not a very elegant way of getting public folder info synced onto my N95. What would be nice is to find a symbian app that is capable of syncing any Exchange folder.
Dataviz's RoadSync supports multiple folders. www.roadsync.com
Rafe wrote:Dataviz's RoadSync supports multiple folders. www.roadsync.com
It's a nice app (In many ways better than the free MFE that Nokia have released) but it only syncs folders within the account mailbox, not public folders.
Edit: I take it back... Roadsync just deleted all of my contacts even though I set it to leave them alone. Pffft! I hope I can find my backup!
Ah sorry I should check before I type 😊
