It looks like this out is out now
http://www.ncp-e.com/en/downloads/software.html
Im gonna try it with my draytek, been looking for a vpn client for a while now.
how good are draytek routers? lol
johnfeshie wrote:It looks like this out is out nowhttp://www.ncp-e.com/en/downloads/software.html
Anyne knows how to use the new nokia vpn client with cisco concentrator or openswan? The instructions are only for nokia VPN or checkpoint.
md27514 wrote:Anyne knows how to use the new nokia vpn client with cisco concentrator or openswan? The instructions are only for nokia VPN or checkpoint.
I've outlined my VPN setup (Nokia E71) on http://wiki.paepstin.info/nokia:vpn
The main difference to the previous nokia clients (E60) was:
1. XAUTH seems to be required. If I disable it on both sides, it does not work. Currently unsure if it's an Nokia or Openswan issue.
2. I needed a small change in the NAT Traversal priorities, since the 'new' RFC style NAT traversal does not work, as long as both sides are NATed.
3. Great thing: no need to sign the VPN configuration anymore.
matthias
Does it (or any VPN software for symbian) support PPTP?
bartmanekul wrote:Does it (or any VPN software for symbian) support PPTP?
I'm not aware of any. IPSEC only as far as I know.
Matthias,
I don't understand you comment
"It does not work with the E51 and the E71. The pre-shared setup works on my E60."
you posted on your wiki.
sezuan wrote:Hi,I've outlined my VPN setup (Nokia E71) on http://wiki.paepstin.info/nokia:vpn
matthias
What exactly doesn't work on E51 and E71 but does on E60?
md27514 wrote:I'm not aware of any. IPSEC only as far as I know.
Damn. Thanks for the info though.
md27514 wrote:Matthias,I don't understand you comment
you posted on your wiki.What exactly doesn't work on E51 and E71 but does on E60?
I transfered my working preshared-key VPN config from the E60 to a E51 and E71 and it didn't work.
Then I tried a certificate config (I never tried this on the E60) and it didn't worked on the E51 and E71.
After activating XAUTH on both ends, the VPN works with the E51 and E71, too. Both, pre-shared key and certificate based. So, both configs on that wiki page should work with Openswan and the new Nokia VPN Client.
matthias
So XAUTH is now required. I'm going to try it on my N95, I have an older setup working on it now (using old VPN client intended for N80).
I had not trouble getting the new nokia VPN client to work using PSK (activating XAUTH). But for some reason the RSA authorization using certificates doesn't. My VPN policy refuses to install.
md27514 wrote:I had not trouble getting the new nokia VPN client to work using PSK (activating XAUTH). But for some reason the RSA authorization using certificates doesn't. My VPN policy refuses to install.
I forgot to add two things to the wiki.
1. You have to add the certificate files. Then .p12 file, which contains the mobiles certificate and keys. I assume the name doesn't matter and it should have just the extension .p12. This is file refered as user-1.cer and user-1.key in the mobile's configuration.
2. You have to add the root ca (ca.crt in the wiki) file. But it must be converted to the DER format. You can do that with this command:
openssl x509 -inform PEM -outform DER -in ca.crt -out ca.cer
In the mobile's config it's:
CAs: 1
FORMAT: BIN
DATA: certvpn-ca.cer
matthias
I'm trying to set up a policy with the Nokia Mobile VPN Client Policy Tool.
How on earth do I set up a policy that uses Xauth with username and password, and that includes a 'Shared secret' for the group name?
md27514 wrote:So XAUTH is now required. I'm going to try it on my N95, I have an older setup working on it now (using old VPN client intended for N80).
Hi, there is updated VPN client available in http://www.businesssoftware.nokia.com/mobile_vpn_downloads.php
that makes it possible to use mode config without xAuth.
There is also new VPN Policy Tool version that has template for xAuth with username/password. Template name is Cisco_ASA_pskxauth
Hi, I followed this (http://wiki.paepstin.info/nokia:vpn) guide, but when I try to install the policy files (both .pol and .pin zipped into .vpn) in tells me "Failed to install policy 'policyname', reason code -1".
I am trying to install the psk policy (e71.conf - PSK) with no xauth.
My phone is a Nokia Xpressmusic 5630.
Cheers
up
up
