Help with best video convertor output
2 replies · 3,367 views · Started 18 July 2008
Hi can anybody tell me the best sound settings when converting a dvd/video to mp4/3gp etc ? ie im using Media studio for nokia and im finding this the best so far as ive tried all others and this seems to give the best result, but i just want to no the best settings to get the loudest sound out when converting, also all the other settings would be great aswell if anybody can help,
Hope to hear soon from brian p-s and or your recommendations please
It may not be an overtly technical answer but I have successfully converted nearly 100 movies by just dropping them into Divx converter with the mobile setting enabled.
I used to use Super on my PC and Core player on the N95. Now I just use Divx converter on the PC and Divx player on the N95 and spend more time watching movies than trying to convert them into a mobile format.
http://www.divx.com/mobile/
Hi, and thanks for that as i may try the divx convertors etc, also what dvd ripper do you use and do you have any dvd aswell ? also what are the best settings that you use for converting dvd/videos etc to your phone, ie birate/audio/video settings etc?
Thankyou for your help and hope to hear soon from brian
