They're available in stock at DOML. I've just bought one from their retail store. You can order it online from them at, http://www.doml.com.sg/product.asp?id=763
Mg 64Mb Duo Available in Singapore!
Can you confirm that the Magic Gate version of 64MB the Memory Stick Duo actually works with the P800??
[quote="SingaporeP800User"]They're available in stock at DOML. I've just bought one from their retail store. You can order it online from them at, http://www.doml.com.sg/product.asp?id=763[/quote]
Hi SingaporeP800User,
Does it work? Been reading various opinions about the ability to use the MagicGate Duos on the P800. Me espicially would like to use them to store MP3s and not ATRACS. Thanks.
AnotherSingaporeP800User
Yes, it's working on my P800.
hey that is really good news then. MG works on the P800!!!! 😃
Where can we get 64mb STANDARD memory stick duo ( instead of MG version ) ?
Seems to me that for the average user .... the standard memory stick is sufficient. Dont think we'll really need the MG copyright technology.
... unless both 64mb version are the same price .... 😊
Anyone knows where we can buy standard duo 64 mb ?
Well the thing is that the standard MS Duos are not out yet. To add to that the Magic Gate versions cost like 50% more expensive.
