Help on pc suite
7 replies · 1,775 views · Started 08 February 2003
Hi guys,I need help in doing an op on pc suite...I'm about to format my 9210i,I've backed-up everything in my pc. The question is:after I've formatted my 9210i and re-installed all-nokia-data-sis and my 9210i is ready to work again,how do I install my back-up data that is in pc suite to my 9210i? Thanx...I'm no good in using pc suite!!! Is there a guide somewhere??? :-?
you don't have to reinstall anything.
format d: using file manager
format c: using the key combo
than connect to your pc
press "archive control"
and click "restore backup"
and all is done... you won't even need to reinstall stuff...
but if you want my advice ... I would reinstall everything and only get your data files from the backup (the select files to restore function)
yah, you're right! 8)
Am i too late?
I think it would be a lot easier if u jst backup ur communicator in the MMC. It will be a lot less of a hassel & it does restore every single thing the time u wana restore it to ur communicator!
