Not all notebooks or desktop computers have a built-in web camera. With desktop PC�s, this isn�t that big an issue: as you don�t carry them around, you can just buy an inexpensive, clip-on USB camera and you�re set. Not so with notebooks, UMPC�s or Tablet PC�s � with them, purchasing (and carrying!) a cabled solution might be overly suboptimal. Then, just using your camera-equipped smartphone may turn out to be the best solution; preferably over a wireless connection like Bluetooth. This way, you can avoid having to carry around a separate webcamera. It�s indeed big help!
Setting them up is exactly the same as with setting up traditional USB cameras. This means they�re really easy to use. In general, you just run the installer EXE file on the desktop you�d like to use your phone connected to. Some of the desktop-side (let�s call them server) apps ask for being started at boot-up time. If you aren�t afraid of the additional memory (and possible CPU) use, you can safely allow this; if you are, just untick the checkbox.
1.1 Starting the server on the desktop
After this, whenever you want to use your phone as your webcamera, start the given server on your desktop. That is, start (in the order of discussion), in Start/Programs, start
WebCamera Plus/ WebCamera Plus
Mobiola Web Camera for Windows Mobile / Mobiola Web Camera for Windows Mobile
Mobiola Web Camera for S60 / Mobiola Web Camera for S60
wwigo/ wwigo
SmartCam/Smartcam
After this, most of the apps start waiting and you can directly start the client on your phone and initiate the connection. The exceptions are:
* Mobiola Web Camera for S60, where you may also need to set the connection method:
Note that these radio buttons are completely missing from the Windows Mobile version as it supports fewer ways of connection
* Wwigo, where you need to click the leftmost button, "wwigo video" for the server to be able to receive connection requests:
If you plan to connect via USB cable (and not some kind of wireless connection), you�ll also need to connect and wait for ActiveSync (Windows Mobile) or Nokia PC Suite (S60) to be activated. (This also means that, on S60 phones, you�ll need to select the standard suite transfer mode.)
1.2 Starting the client on the phone
On the phone (the client), you will need to do the following in order to start the connection (in the order of further discussion; first, Windows Mobile titles and, then, Symbian ones):
1.2.1 Windows Mobile
1.2.1.1 WebCamera Plus
In Menu / Source, switch to Front Sensor if you want to use the front camera as your camera. Otherwise, use Camera to switch to the back camera. It�s also here that you can en/disable sound capture (using which isn�t recommended if you already have a mike built-in into your desktop because, at least in my case, the transferred sound was much choppier than with using the built-in mike of my TC1100):
In Menu / Settings / Camera, you can set a lot of goodies like saturation, rotation, mirror, resolution, quality:
If you plan to use WebCamera Plus via USB or Bluetooth (both via an active ActiveSync, previusly-started connection), there isn�t anything else to do � just click Start. If, on the other hand, you use a wireless TCP/IP connection (either BT PAN � if your phone supports it at all �, Wi-Fi p2p or even long-distance TCP/IP connections like GPRS), you will need to set the (local network) IP address of your desktop. You can do this in Menu / Settings / Network:
1.2.1.2 Mobiola Web Camera for Windows Mobile
Start the server and, then, the client. Go to Menu / Connect / ActiveSync to connect via either USB or Bluetooth or Menu / Connect / Wi-Fi if connecting via a Wi-Fi p2p network:
