Disappearing mailbox?
6 replies · 4,806 views · Started 21 July 2008
I have not been able to track down exactly what might be causing this, but my brand new 6120 seems to be dropping/losing the mailbox account I set up on it. The first time it happened I figured it was a fluke or I did something. Then I set it up again. It's now disappeared once more. This is a rather odd problem I've NEVER had on a phone before. I cannot pinpoint any particular action that I have taken on the phone that would cause this to occur. I've tested it by turning the phone on/off, changing profiles, themes, but so far nothing. It seems to happen overnight. I'll be watching more closely what exactly it is.
If it were a more minor setup consideration, I wouldn't be so annoyed, but setting up a mailbox with all of the various settings is time consuming.
In the meantime is there any way to backup a mailbox setup so I can just restore it again when this happens again? I assume it will.
Weird... Backup, as far as I know, no! Check if you have the last firmware version inside. Last one: RM-243 V 5.11
nj7 wrote:Weird... Backup, as far as I know, no! Check if you have the last firmware version inside. Last one: RM-243 V 5.11
The software updater is telling me 4.21 is the latest and that my phone already has it. Where else can I find the 5.11 firmware?
nj7 wrote:NSU - Nokia Software Updater; just see here how to do: http://europe.nokia.com/A4579163
I haven't been able to try this yet, but through Nokia's PC Suite Updater (is that the same thing?) and the phones OTA updater, both say I'm up to date with 4.21.
Also Nokia's http://europe.nokia.com/A4577224 page says 4.21 is the latest firmware for product code 0547593.
I'll give the separate update software a try tonight. Is there a manifest for the 5.11 update? What's been fixed there?
Maybe you have the last one for your Product Code. Some others have the version V05.11 from 21-04-2008. If you have the last one, nothing to do from that side:frown:
