Hi
Can anyone recommend a good, reliable bluetooth usb dongle for the N95. The one I currently have (Itech bluecon) I find terrible - both the hardware (often makes a loud buzzing noise from the device itself) and the software (hate the UI of Bluesoleil).
Thanks in advance!
Recommended bluetooth dongle for N95
i have the Belkin dongle from ebuyer for about a tenner. there are cheaper ones but then you have to pay for the software which is pants!
Thanks Casper. And the Belkin dongle works well? What software does it use?
I've read that it can be better to use the built-in BT software on windows xp than the software with the device - can anyone confirm this? If so, how do I go about setting this up?
Sorry for all the questions, just find BT very difficult to use for some reason!
