SeleQ for P800, where is it?
2 replies · 2,063 views · Started 08 February 2003
One thing I feel it missing from the P800 is a Filemanager, you get the file structure of certain folders for the memory stick/internal memory when using 'My P800' and also Symbianware have released a program for viewing all files but only when your P800 is docked in a PC.
What we really want is a Filemanager on the phone, coming from a 7650 SeleQ www.ximplify.com was one of th best ones. I'd like to think there would be a P800 soon.
What do all you guys think?, oh and one more question, has anyone managed to change the OPLOGO yet? I doubt it will be the same as on the 7650, but you should be able to replace with an image of your choice using the 215_15_123.jpg (Or your operators ID) in a certain folder type way method.
Here's a File Manager. It's not exactly SeleQ, but it does the job. I find it very useful, and it has a task list where you can close running apps.
