I'm sorry for posting here, but there doesn't seem to be a 6220c area to post in.
I'm having trouble with the gmail app. it downloaded properly but when I try and open it I get the following error message:
"java.lang.IllegalStateException: This method is not supported in com.nokia.mid.ui.fullcanvas"
Does anyone know what this means? How do I fix it? Has anyone else experienced this with the gmail app using a 6220c? Is this a FP2 issue?
My gmail account works fine using message app but, you can do more with gmail using there app. Any help would be appreciated.
petersonwd wrote:I'm sorry for posting here, but there doesn't seem to be a 6220c area to post in.I'm having trouble with the gmail app. it downloaded properly but when I try and open it I get the following error message:
hello,
same pb
is there a solution ?
The application still dosen't work but if you use www.gmail.com it seems to put you into the mobile application automatically. At least it looks very much like their mobile apps version.
I have a 6110, I installed the Gmail app and it worked fine for a couple of days. Then today, I doesn�t want to start. I had the same thing with the Yahoo app, but that worked exactly once and never again.
