Hi all,
I changed my e71 Product code from 0560654 to 0567045 (euro) but, on "Nokia Software Update", the button "Reinstall" does not appears, so I can't reflash it.
Any tip for me?
Regards,
Laco.
Hi all,
Any tip for me?
Regards,
Laco.
although the Nokia update recognises the E71, there are no update available, so they haven't uploaded the current firmware.
Until they release a new firmware you won't be able to use the product code change method.
It is possible to reflash using phoenix if you can find a copy and the current firmware file.
I got the Phoenix Software and the Firmware set but when trying to update a error occurs: cannot put the phone on flash mode... the phone turns off but nothing happens....
lacordaire wrote:I got the Phoenix Software and the Firmware set but when trying to update a error occurs: cannot put the phone on flash mode... the phone turns off but nothing happens....
where did you get the firmware set?
I desperately searching whole internet...
thanks!
fire00 wrote:where did you get the firmware set?
I desperately searching whole internet...thanks!
I can give you the links but I believe you need special cables and box to be able to flash the phone. I also want to do this as I have E71-3 and I need to load E71-1 firmware in order to get my 3G working (different frequencies).
I'd appreciate if you gave me the links!
RE flashing - actually I was watching a phone dealer flashing the Nokia yesterday just with normal USB cabel and a tool called J.A.F. or so....it should work.
fire00 wrote:I'd appreciate if you gave me the links!RE flashing - actually I was watching a phone dealer flashing the Nokia yesterday just with normal USB cabel and a tool called J.A.F. or so....it should work.
Here you go
h..p://rapidshare.com/files/126743179/RM-346_APAC_100.07.76_v1.0.part1.rar.html
h..p://rapidshare.com/files/126743198/RM-346_APAC_100.07.76_v1.0.part2.rar.html
Fix the http in the beginning of the links.
Let me know if you had any luck.
Cheers
Is there no way to use this firmware file via USB with PC Suite or NSU?
I am having so many bugs with this device it's unreal. I also want to debrand from 3 to the basic Nokia firmware, so I can start afresh from there.
Any advice would be greatly appreciated! :icon14:
Also, from all your past experience (I am new to Nokia), how long before you imagine they will release new firmware for the E71?
