n91 memory problem
2 replies · 22,736 views · Started 26 July 2008
Im using a Nokia N91 and its always showing a memory full messege. And i can not get to find whats using up all my memory, i even tried deleting everything in the intenal memory, but still. My harddrive has only used 1GB of the 4GB but i still have a memory problem. And even worse now, my phone can not switch on. When ever i switch it on it brings the memory low message and immediately switches off. I dont kno what to do with this problem and seems like i have lost my phone already but if you can help me with this problem i will be very much thankfull. pls...
:con?
Try reformatting it by powering it off, then pressing down the three keys '3', '*' and green/talk, and while these keys are pressed down, turn the power on (don't release the three keys). It is a bit tricky (you need really a 3rd hand to do it properly), so it might take a while to get it right.
After that, reformatting the hard drive, will also reset it.
If not enough, you can also try Nokia Software Updater ( http://www.nokia.com/softwareupdate ) to get the latest firmware.
