Hi Everyone,
here is my problem
I am currently using Nokia N73 In Canada with latest Firmware upgrade. And I was not able to get on 3G ever. However i can get on Internet with. Neither I cannot make video calls from my headset. Can someone correct me and help on how to activate 3g and video calls.
I may be missing some settings.
Any help and advice would help a lot.
thank you
1st, check your phone using this code .. *#0000#
if the detail you see there.. RM-132 .. you wont be able to use 3G with your phone..
if it's RM-133 .. then check your signal bar on top-left your phone screen, there should be a 3G icon under it.. if there isnt, you wont be able to use 3G..
if you have it.. then, check with your service provider ..your network telecommunication service.. ask them to set it for you.. it should work then
