Where Can I Get Divx
2 replies · 4,758 views · Started 29 July 2008
Hello
you want to find DivX you say??
Well, first things first, DivX is a type of compression format to make movies small enough to fit on your memory card in your phone.
You need DivX Player for Symbian S60 3rd Edition phones -
http://labs.divx.com/node/6211 - (you may need to sign up). Install this on your phone.
Then you need to find a website that offers DivX movies, like piratebay.org OR you can compress your own DivX movies using software like Smartmovie, its a lengthy process compressing a movie, it can take around 1hr20mins.
www.google.co.uk is your best friend!
Regards
Markkyboy
p.s. i've been using DivX for years & years but watching a movie on your phone does not do ANY movies ANY justice! (just my opinion!)
I never got on that well with Smartmovie, it seems slow and relatively awkward.
Personal preference was to use VirtualDub - considerably faster, and more flexible, albeit relatively awkward to use (having to specify resize filters, etc.)
Another option is to use the Nokia multimedia converter, which works incredibly well for the N95 (although very, very slow) - haven't tried it for the N73 though.
