I have solved the problem with syncing, but now I hav another problem.
The P800 doesn't sync all day events (like birthdays) with outlook... Is there a setting or something?
[quote="Robban"]I have solved the problem with syncing, but now I hav another problem.
The P800 doesn't sync all day events (like birthdays) with outlook... Is there a setting or something?[/quote]
I experienced the same problems too. But all-day events does sync from P800 to outlook. Not the other way (outlook to P800)
:roll:
I asked SE about this, claming that this is a quite annoying bug. Their answer was this:
> Hej !
> Tack f�r att ni kontaktade Sony Ericsson Customer Care Center.
> P800 har ej st�d f�r �terkommande heldagsh�ndelser
> vid synkronisering. I dagsl�get finns inga planer p� att
> implementera st�d f�r detta.
> V�nliga h�lsningar,
> /Xxxxx
This basically says that they are aware of the fact that whole day appointments does not get synchronized and that they do not intend to fix that either. 😞
/Toby
Well this is a really losy behaviour by SE. How should one manage all birthdays and such things? Add them at a spcific time?
Totally unbelivable!
I hate that too, cause now I will forget all my families birthdays 😮ops: . Is there someone else who made a special Birthday App????
It does sync all day events. Just not the recurring ones (like birthdays) (at least on my version). It is still annoying bug though.
There is something in the manual about this. They don't support all-day recurring entries. Hope this will change!
The most anoying about this is the attitude that they don't intend to correct it...
